Do i need a relay
It really depends on the switch that you use. Since these are LEDs, they draw a low amount of current. 27W/12V=2.25Amps per light. So long as your switch is good for 4.5 amps plus 10%, you will be fine without a relay. There are plenty of switches out there that can handle that small amount of current.
Things change when you are running regular lights and multiples of them...lots more current there.
