Dual battery selection
I'm getting ready to install a dual battery system with a Cole Hersee isolator. I wanted to go with a auto battery for the main and a marine battery for the second. Does it matter? Or should both batteries be the same?
Both batteries should be the same. I went with 2 diehard platinum marine batteries in my setup.
I assume your dual marines are running fine. |
Originally Posted by NeverStock
Is the isolator the only thing needed to run the dual battery set up?? Other than the dual battery tray and some extra cable. The isolator can also option out with a boost switch or indicator light etc. but it (isolator) doesn't have too. It just gets connected to each battery and runs on its own. Isolating the batteries when necessary not to overload the alternator and not drain your main battery when running your accessories. Probably tmi, but take a look on the forum or look at the packaged kits out there by companies like rugged ridge. |
(Post 2729926)
You need a certain isolator. I would get the die hard 34 group battery as its a odyssey rebrand battery. Pm and I can give you more spec. I can't post them on my
Phone |
1 Attachment(s)
I went with 2 platinums auto batteries. I still think maybe I should have gone with the marines. (both have same cold cranking amps)
Attachment 253950 |
(Post 2747102)
Attachment 253950 |
Originally Posted by SlowJK
(Post 2747357)
You have the best setup for the money. I would stick to auto batteries, the platinum have amazing no charge time on them. As they are re=branded Odyssey batteries one of the best on the market right now. Stay the hell away from optima.
| All times are GMT -8. The time now is 12:11 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
