Easy Rocker Switch Mount Above Rear View???
#21
Correct me if I'm wrong, Mark, but the current draw is a factor of the circuit design. The limiting factor in the control circuit is the coil in the relay. If you short the ground, the current coming through will be limited by the coil. If you short the power side, there is no limit and you will most likely melt the wire itself. That is why if you short the ground side all you do is activate the relay circuit, not blow the relay. Typically the control circuits are not fused. Additionally, half the wires running through the firewall equals half the chance for a short.
But you're right as long as there is not a short in the system, the draw will be the same on both sides of the coil. At least that is my understanding.
#22
No, I think we're in agreement. The two things I was commenting on were something about less power draw (which is why I cited current, since power is consumed mostly at the load and not in the wiring, one would hope), and the consideration for a failure that could cause property damage or physical harm.
#23
Oh, and it isn't necessarily twice the wiring through the firewall. One wire (fused) carrying 12 volts to every switch, plus one wire for each relay coil. Or, you could have two circuits, one for positive-switched circuits, the other for negative-switched. Assuming chassis ground (no wire through firewall), only the one positive wire is added. Right? I'm drawing this in my head, LOL.
#24
Mark, you are right about some things should not be controlled via the Gnd and gave the perfect example. As said earlier I was speaking of the switches that actuate relays for lights. The current draw from relay coils at 12v is under an Amp and a 24 awg wire will handle that with ease, but if you short the positive side you will surely burn the wire along with the fuse. If the gnd side shorts the device will turn on and the most likely wont blow. Wiring and component rating is a always a balance between worst case and some acceptable risk.
#25
#28
I just bought some KC lights and I'm looking for directions on how to wire them up to rocker switches. I'd like to wire a rocker panel above the rear view mirror but there doesn't seem to be a cheap option for that, so I may just go with the space in front of the shifter.
I'm not entirely sure how the power fairies work but I'm sure I can figure it out with some guidance or some photo directions. Is there a link on the forum for what I'm wanting to do? or can someone Explain Like I'm Five?
#29
#30
I do... sorta... lol
The handmade versions are available but you need to message me.
I'm in the process of having patent work completed as well as molds and production. It just takes time due to the cost... which is fairly high.
