ESP switch!!!!
I didnt think it would work seeing that the esp button tells the computer what to do and if you want it permenantly turned off you have to tell the computer by doing the steering wheel trick. Now breaking the circuit to the esp switch, i would think, would just not allow you to use the esp button not permenantly turn it off like youre thinking.
Thats just my 0.02. Im curious to see how this plays out.
DONE!!!! just got in from finishing up the ESP kill switch.. only other mod that is easier is the mirror drill mod
cut the purple wire with LIGHT blue stripe.. spliced it from and to a rocker switch.. all worked out GREAT.. thanks for the tips guys!
cut the purple wire with LIGHT blue stripe.. spliced it from and to a rocker switch.. all worked out GREAT.. thanks for the tips guys! I want to do this on my 09' Rubi. I this "purple wire" at the esp switch?
Now does this just turn off the ESP or ABS and BAS with it?
So I drilled through the switch pod and now I can't turn the hazards on or the esp off. I like the idea of putting a switch in for the ESP, but would it work for the hazards also?
