Factory Fog Replacement options?
Looking for a factory fog replacement options.
Requirements:
1. Fit in factory holes in bumper
2. Uses factory fog light switch on turn signal
3. Can connect to factory wiring (with or without adpter)
Is there...ANYTHING out there?
Requirements:
There are literally tons of options, you can upgrade to leds, stick with oem replacements al under the parameters you've indicated... Check these:
http://www.rebeloffroad.com/product-...ledfog5052.htm
LED Fog Light Upgrade for 2007-2013 Jeep JK (pair)
Check out this thread:
https://www.jk-forum.com/forums/jk-w...ctures-127045/
I bought these and replaced mine. They are the Pilot PL203W. You can get them for around $40 at your local AutoZone, or other auto shop. If you don't mind the blue lens, they work great. Much brighter than stock and very cheap.
I replaced mine because one of my bulbs burned out. I went by the dealer to get one and they wanted like $54 for one bulb!
I'm real happy with these.
Out of curiosity, what is the highest wattage anyone has ran in the stock holders? I have been running 55w without issue, just had to run them through a relay so I didn't agitate the computer! Im just wondering if anything higher would actually melt the housings, or if they would be that much hotter.
I just installed rigid d1 using poison spyder adapters. I used rigids wiring directly to the battery.. I put the switch the empty hole in the pillar by the windshield. It took a few hours but I cannot live without them. I have been testing oncoming drivers and no one seem to be bothered by their brightness. I suppose since they are low enough to the ground.
