JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   JK Electrical, Lighting & Sound Systems (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/)
-   -   Factory Fog Replacement options? (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/factory-fog-replacement-options-253020/)
flienlow Nov 1, 2012 12:01 PM
Looking for a factory fog replacement options.
Requirements:
1. Fit in factory holes in bumper
2. Uses factory fog light switch on turn signal
3. Can connect to factory wiring (with or without adpter)
Is there...ANYTHING out there?
Skid_Kid Nov 1, 2012 12:04 PM
Delta makes them.
Delta Tech 013039-JKX - Delta Fog Light Upgrades for 07-09 Jeep® Wrangler & Wrangler Unlimited JK - Quadratec
Atlacatl Nov 1, 2012 12:06 PM
There are literally tons of options, you can upgrade to leds, stick with oem replacements al under the parameters you've indicated... Check these:
http://www.rebeloffroad.com/product-...ledfog5052.htm
flienlow Nov 1, 2012 12:09 PM
This is why I LOVE THIS FORUM!~!
Thanks guys.
:grouphug:
Glorybound Nov 1, 2012 12:26 PM
Check out rebel off road. They have led replacement plug and play....
flienlow Nov 1, 2012 12:34 PM
I just called rebel off road. They told me the P&P LED is no better than stock and is just for looks :(
LED Fog Light Upgrade for 2007-2013 Jeep JK (pair)
jcopel Nov 1, 2012 01:23 PM
Check out this thread:
https://www.jk-forum.com/forums/jk-w...ctures-127045/
I bought these and replaced mine. They are the Pilot PL203W. You can get them for around $40 at your local AutoZone, or other auto shop. If you don't mind the blue lens, they work great. Much brighter than stock and very cheap.
I replaced mine because one of my bulbs burned out. I went by the dealer to get one and they wanted like $54 for one bulb! :naw:
I'm real happy with these.
k0260 Nov 1, 2012 01:27 PM
I simply changed out bulbs for Sylvania Silverstar's, much whiter and brighter than OE.:dontknow2:
Wrangled Nov 1, 2012 03:24 PM
Out of curiosity, what is the highest wattage anyone has ran in the stock holders? I have been running 55w without issue, just had to run them through a relay so I didn't agitate the computer! Im just wondering if anything higher would actually melt the housings, or if they would be that much hotter.
Harrishill Nov 2, 2012 11:12 AM
I just installed rigid d1 using poison spyder adapters. I used rigids wiring directly to the battery.. I put the switch the empty hole in the pillar by the windshield. It took a few hours but I cannot live without them. I have been testing oncoming drivers and no one seem to be bothered by their brightness. I suppose since they are low enough to the ground.
© 2026 MH Sub I, LLC dba Internet Brands
