Factory installed inverter
Old Nov 1, 2010 | 07:24 AM
Lorrel's Avatar
Originally Posted by ronjenx
Nicely done, but there are a few things to consider.
#10 wire to an 800 watt inverter is too small. Should be #6, maybe even #4.
A 30 amp fuse is too small for a 800 watt inverter. 70 amps would be more appropriate. (Assuming the proper wire size is used.)
Nice catch, and I agree he's pushing it, however after calculating myself, I come up with the following:
Using a VDC of 14 which is most likely what the alternator is putting out on a running engine, with a copper stranded wire with a length of 20ft at a temp 100*F, the amperage would be 33.03. At 12VDC, same wiring length and temp the amperage would be 38.54. With that in mind using MIL-STD-975 the wire rating should be a #8. That would allow for 44.6 amps which would be below the highest requirement which would be 12VDC. I would say a #8 stranded copper wire with a 40amp fuse would fit this application safely.
Old Nov 1, 2010 | 10:35 AM
shockwaveaz's Avatar
Please explain how that would only be 38.54 amps @ 800 watts and 20 ft. ? I would like to know how I am coming up with much different numbers for much future projects. I learn so much here.
Not accounting for temp and length 800/12 is 57 amps. With the cable length and voltage drop and heat it will only go up. Min would be six gauge wire and a70 amp fuse. Also peak (although short) is 1600 watts.
Sent from my EVO using Tapatalk.
Old Nov 1, 2010 | 10:48 AM
JK-Ford's Avatar
Sorry "Lorrel" I beg to differ!
One can not assume 14 vdc. !2 volts should be the minimum. So your calculations should start there.
As I have stated many times before. Calculating length of conductor is pure BS. Just simply calculate the full load and adjust the wire size to those specs.
I have not looked up what you are refering to here. I will later. But my referance comes from "The National Electrical Code" ( NEC ). In other words "The Electricians Bible".
X2 X2
Old Nov 1, 2010 | 11:08 AM
Originally Posted by JK-Ford
Sorry "shockwaveaz" I beg to differ!
Are you saying you agree its only going to draw 38.54 amps? I agree deff should be calculated at 12 volts with a 1 percent tol. Im just trying to learn why you feel it would only draw 38.54 amps at an 800 watt load.
Old Nov 1, 2010 | 11:18 AM
JK-Ford's Avatar
800 watts / 12 volts = 66.66 Amps
66.66 amps = 70 fuse / relay
70 amps = #4 THHN conductor
Old Nov 1, 2010 | 11:27 AM
Oops I just realized I typed 800/12 meant 14 since I was using their example. X2 on your post that's what I was thinking. Didn't understand how they came up with the low amps. Thanks
