Fan/overheating issue
I've searched high and low to find a solution to this. I got the P0480 code. I replaced the J11 fuse, the fan relay, and a new thermostat. The Jeep still shows the check engine with the P0480 code and when sitting in traffic the temp gauge climbs. From what I've read the next step is to replace the entire cooling fan? Any ideas, thoughts or experience?
There are no other codes showing. I did a radiator flush and so far it has been good. The check engine light still comes on occasionally, but it does not overheat anymore.
My 2012 experienced overheating while stopped in traffic. In my case it was due to a loose connection on the battery of something I think was called a fuse link. Because of the loose connection of this link, the fan was getting intermittent voltage. Tightened up this connection and it has been fine since. That was maybe 5 yrs ago.
