Finally Installed the Gauges
Old Jun 16, 2008 | 10:54 PM
JK07's Avatar
Default Finally Installed the Gauges
VOLT Gauge / OIL PRESSURE GAUGE / OIL TEMPERATURE GAUGE
Gauges On
They are pretty bright i think the picture quality is not good enough
Gauges Off
Old Jun 17, 2008 | 02:47 AM
JKJunkie's Avatar
Nice job!
Old Jun 17, 2008 | 04:58 AM
wvmtnbiker's Avatar
How do you have the GPS mounted? Is it suction cupped to the windshield or did you attach it using the sun visor mount?
Old Jun 17, 2008 | 06:50 AM
serveapurpose's Avatar
Sponsoring Vendor
Off Road Evolution Rep
Nice job! I am installing my gauges in the same location with a little different mount. What size are the gauges and what brand? I was planning on the Auto meter G2's 2 1/16.
Old Jun 17, 2008 | 02:53 PM
JK07's Avatar
I have used Auto Gauge 2"/52mm. They came with all the hardware including senders. I have also used the 2"/52mm Gauge Pillars or mount.
Old Jun 17, 2008 | 07:06 PM
Sponsoring Vendor
Thanks mate!
Old Aug 18, 2008 | 08:12 AM
dnhenson's Avatar
You did a great job. What wire did you use to get the lights to turn on?
Old Aug 18, 2008 | 01:46 PM
whybnorm2's Avatar
Could you post pics of where you hooked up the sending units. I was thinking of getting the same types of gauges. The first time I went off-roading with my JK I noticed it didn't have oil pressure or volt meter like my old TJ. Looks great though.
Old Nov 27, 2008 | 06:35 PM
looks great. However, I've got to find a better place for the gauges because I have a **** coming which mounts in that location.
Last edited by JackMac4; Mar 16, 2009 at 12:02 PM. Reason: removed blacklisted mfg
Old Nov 27, 2008 | 07:00 PM
thebigtman's Avatar
Looks good.
