Fog light install issue
Old Nov 25, 2010 | 07:07 PM
Eeepj's Avatar
Default Fog light install issue
Installed Body Armour front bumper and really missed the fog lights from the factory bumper so I bought some aftermarket lights to hookup to the original fog light wiring and they don't work? They will light up for a second then go off. Any help would be appreciated.
Old Nov 25, 2010 | 07:19 PM
genesbro's Avatar
You will have to have your factory wiring activate a relay that will provide the power to your fogs. The smart fuse box does not like the load that it sees and is cutting the power.
Old Nov 26, 2010 | 04:02 AM
wallawallaron's Avatar
First off welcome to the forum.....There are a lot of good posts RE: 2007 JK's with this issue. Try the search .. But as said in prior post you need a relay.
Hope this helps....
Old Nov 26, 2010 | 07:08 AM
fm3fm3's Avatar
Originally Posted by Hkx3
I just bought 55W fogs and installed on the factory circuit.
Works fine.
The guys running stadium lights need to, as pointed out above, use the factory circuit as a trigger for the relay in the stadium light kit.
I also replaced the factory bumper on my 2007 and miss my fog lights. What brand of fogs are you using? Are you happy with them?
Old Nov 26, 2010 | 05:32 PM
Eeepj's Avatar
I tried the search for lighting issues but couldn't find the answer. Can someone explain how or where I install the relay. Any help is really appreciated.
Old Nov 26, 2010 | 05:41 PM
Saharaunlmtd's Avatar
Do you know what the wattage of your new fog lights is? I installed the aftermarket 55w xenon delta lights in my bumper after both lenses cracked. I used all of the supplied wiring except for the switch. You can pull the white wire out of either fog lights and wire that to the switch wire. That way they will work with your factory switch.
The factory foglights were only 42 watts so that can create issues.
Old Nov 26, 2010 | 05:43 PM
Default fog lights
Hey, i installed some Blinglights in the openings of the original fog light location, and just used an alternative auxiliry switch. Didnt want to have the problem your having.
Old Nov 26, 2010 | 05:45 PM
genesbro's Avatar
https://www.jk-forum.com/forums/show...hts-to-brights
That link in this same section has a picture that should help you out. You would connect the two wire from your oem fogs to 85 and 86 to control the relay.
Old Nov 26, 2010 | 05:46 PM
http://www.mp3car.com/vbulletin/faq-...w-wire-up.html Also try and send a message to forum member riptide,gensbro or echo they are great at this type of issue . hope this will help......
Octo's Avatar
This might help,
h t t p://www.bcae1.com/relays.htm
Sorry about the bad link, but there are some rules on this forum about posting links to certain external sites, so I just play it safe.
