Fog Light Wiring Help
wow, zombie thread.
what part number are you looking for?
if your X didnt come with factory fogs, you dont have the wiring or the stalk switch. you can simply use a relay & switch like any aftermarket light, or install the stalk switch & wiring. People have done it, but i'm not 100% sure you can buy the wiring/switch without the fogs in the kit.
Any dealership can order it for you.
"Installation kit is a wiring extension allow relocation of Fog Lights to a Mopar Brushguard (97-06 Wrangler) or Off-Road / Winch Bumper or Tubular bumper lamps for 07+ Wrangler
Part #
82210549
Name
: Lights, Fog Light Installation Kits
Jumper Harness
Description
: Connects production fog lamp wiring to bullet style Mopar Fog Lamps. 18 long. Used when installing Mopar bumpers in place of production fog light equipped bumpers.
Price
$22.00"
Part #
82210549Name
Jumper HarnessDescription
: Connects production fog lamp wiring to bullet style Mopar Fog Lamps. 18 long. Used when installing Mopar bumpers in place of production fog light equipped bumpers.Price
$22.00"I just got this "kit" from Quadratec and it is not plug and play. It is from Mopar with the same part number. My dealer will order it but has no idea if they are ordering the right thing and won't return them...The Mopar extension kit I got has the same "male" end as need but no female end, instead it is a different plug all together. Any clues?
Link to what I bought: http://www.quadratec.com/products/97006_150.htm
This is what you ordered and received?
the left bullet style connectors go to the light, the other end goes on the factory wiring, where the bulb used to connect. Remove the bulb, plug it in. Plug your light to the other end. It is the same part used in thier oval foglight kit shown here: (note the bullet connectors on the foglamps)
If the top piece isnt what you recieved, i dont know what is going on. If it is, it should plug right in. What exactly are you trying to do with it? the plugs should all line up.
If you are looking for an extension to a factory 07+ foglamp, just to say move it ?
I do not know of a factory assembled wiring kit to move the OEM fogs outward, the one shown above is used to extend the wires to a bullet style connector, not to the OEM lamp. You could use it for that though. You would simply need to swap off the bullets for an H10 bulb connector. (they are like $8)
An auto parts store should be able to help you with that.
You'll have to wire it yourself most likely though, it will either come with short unterminated leads or no leads at all and you will need to assemble it like the pic above. (it isnt hard to assemble a connector)
I am just trying to move the OEM round ones for my new Shrockworks bumper. I guess I will have to wire this up. How do I wire this crap up now...what auto parts store can I score the connections at?
All your doing is extending the plug, wire the new male end so it corresponds to the female end. As for autoparts stores, i have no idea what is local to you, but NAPA, AutoZone, Advanced Auto... etc. any of them should be able to get it for you, not an abnormal part.
