I removed the factory fog lights due to getting a new bumper so now the wires are just hanging there. How do I remove the wiring harness? Maybe someone has suggestions on using these lights for something else?
Just safe-off the wires in front and tye-wrap them to something.
Originally Posted by JK-Ford
(Post 3456862)
1 Attachment(s)
Originally Posted by Jeepcop
(Post 3456839)
Sent from my iPad using Tapatalk HD |
That's what I am doing now. I actually bought the wire extenders so they plug right into factory harness and the other end has those clamp ends where you insert the wires from the fog lights and then just crimp the wires. I was also told the same thing. As long ad you stay under what the factory lights drew for power you are all set. I was told you could go up to 30 watts. The new lights I bought are I believe 25 or 27 watt LEDs. Will be nice just to use the factory switch. Will post pics once I install.
| All times are GMT -8. The time now is 03:06 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
