Fog lights
This is probably a stupid question...I have a 2013 Jeep Rubicon with an upgrade Warn Elite series front bumper. It was installed by 4 wheel parts. I cannot find how to turn on my fog lights for the life of me! Please help.
Next stupid question
: Did they re-wire the fog lights or are you asking for the normal way to turn on the fog lights?
Normally you just pull the end of the light stalk outwards. This only works when the parking lights or headlights are on.
: Did they re-wire the fog lights or are you asking for the normal way to turn on the fog lights?Normally you just pull the end of the light stalk outwards. This only works when the parking lights or headlights are on.
I have the same bumper! Did you keep the factory lights or did they install aftermarket ones? If you used the factory ones they should turn on the same way they did on the stock bumper (turning your headlights on and pull out on the turn signal switch). If they used different lights they could have wired them into the factory harness which means they turn on the same way. If they put a separate switch somewhere else it could be in many different places.
