JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   JK Electrical, Lighting & Sound Systems (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/)
-   -   Fuse M37 (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/fuse-m37-301288/)
Jhen Apr 12, 2014 03:17 PM
Fuse M37
Fuse M37 keeps shorting,:banghead: cant figure out why. Any help would be appreciated!!
It's an 07, only blows the fuse when moving, drive a mile or so and pop.
Also showing these codes
P0627 Fuel pump control circuit open
P0571 Brake switch performance
V1120 lost wheel distance msg
V0121 lost comm with anti lock brake module
V1110 lost vehichle speed msg
P0585 speed control switch 1/2 conection
P0513 invalid sim key
V0121 again
Lorrel Apr 13, 2014 01:41 AM
Since the fuse you are talking about is for the following:
M37
10 Amp Red
Anti-Lock Brake System (ABS) , Electronic Stability Program (ESP), Stop Lamp Switch (STP LP SW), Fuel Pump Rly Hi Control,
I would look into all the above components for a short. You say the fuse only blows when you are moving, it would seem the fuel pump could be rulled out as it is working any time the engine is running. It could be something as simple as the stop light switch. You could rule it out by simply sitting still and hit your brakes a few times to see if the fuse blows. If not you could rule that out.
Good luck finding the problem. BTW this is most likely the reason you are showing those codes after the fuse blows.
Jhen Apr 13, 2014 01:49 AM
Thanks Lorrel,
I pumped the brakes to try and recreate it earlier, no go. I figured most of the codes were from the aftermath of the fuse. going to pull J6 tomorrow and see if that will remedy the fuse blowing and can narrow it down to the ABS or ESP
Jhen Apr 13, 2014 01:08 PM
Pulled J6, ran for ten miles before it blew m37. 10x longer than it would run before. :thinking:
Jhen Apr 15, 2014 01:36 PM
Took it to the dealer and they wont work on it, because its too heavily modified:mad:
© 2026 MH Sub I, LLC dba Internet Brands
