JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   JK Electrical, Lighting & Sound Systems (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/)
-   -   Fuse tap (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/fuse-tap-269702/)
Rwbgecko2013 Mar 29, 2013 04:12 PM
Fuse tap
Hi
I am planning tomorrow to install my two RR fog/driving lights on my bumper bar. My question is do I need to keep the in-line fuse? Should I just leave it in or remove? I'm using the 10 amp fuse tap suggested by JK-Ford.
OH9JK Mar 29, 2013 04:23 PM
what is the wattage on your lights and what fuse are you tapping into?
Rwbgecko2013 Mar 29, 2013 04:40 PM
I'm putting in a new fuse with a 10 amp rating. JK-Ford outlined the location on one of his posts. The on-line fuse is also 10amps. The harness is for two fog/driving lamps from R Ridge (6" slim).
JK-Ford Mar 29, 2013 06:32 PM
If you are just using this tap for power to switches ( that are switching relays ) , you can use the existing tap to switch the new relay too. Just simply install the new switch. Remove the wire that feeds power to the new switch. Then connect a wire from one of the old switches to the new switch for power.
© 2026 MH Sub I, LLC dba Internet Brands
