Fuse for winch ????
I have a superwinch S9000 winch and am trying to figure out what size fuse i should use, if any fuse at all is recommended.
The loads for the winch are:
73 amps at 0 load
130 amps at 1000lbs load
165 amps at 2000lbs load
240 amps at 4000lbs load
316 amps at 6000lbs load
420 amps at 9000lbs load
Remember you opinion does matter
Thanks
73 amps at 0 load
Thanks
A fuse is highly recommended. And a circuit breaker is even better than a fuse.
Buy the biggest wire that you can afford. Buy a "Slow Blow / "Time Delay" circuit protector that matches the size wire that you buy.
JK-Ford the winch has a #2 cable for the hot side and the ground. So i guess i need a 150amp circuit breaker for the #2 cable.
I do have a isolation solenoid located between the battery and controlled by a switch on the dash so the winch only has power when needed.
Let me know
Thanks
I agree. I also recommend a quick disconnect for the battery. I keep my winch disconnected, unless I plan on using it. If I do, it takes 2 seconds.
Let me know
Thanks
Let me know
Thanks
Hope this helps.
