Gracenote Update
I am trying to update my gracenote DB and am having issues.
I burned the DVD naming the disc GN_1287. The disc contains the root directory GN1287 which contains the GNDB File Folder and the gnupdate file.
I got these files from the xxx.mofv.com MyGig site.
When I put the disc in with the Jeep running it says "reading" then just says "Data"...that's it. I don;t get the prompt to ask if I wanna update or anything.
I have a 2009 REN unit BTW.
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
I got mine from the same place as you did and burned it the same way.
Mine is a 2008 RER
n
I have never updated my gracenotes. lol. maybe I should...
I would do it now, but I don't have a disk with me here at work and those dummies did not make it where you can update the mygig from a flash drive... grrr...
Any thoughts?
Any thoughts?
Make sure you burn the dvd at the SLOWEST speed it will allow you either 4x or 8x.
I tried to burn it on Roxio but it wouldn't let me select the slower speed at all. Maybe I will Nero then. Or maybe I corrupted the file when I downloaded it originally. I will try it again.
I can't get the Gracenot update to work. I have killed 5 DVD R trying. I burned the last one at 2x speed and still got the DATA message. I let the DVD sit in there with that message for over 5 minutes and still wouldn't work. Iam pretty computer savy and cant figure out why this is not working. Any help or suggestions would be appreciated.
