Heeeaalllllp !!!!
So the skinny , 2012 jeep jk , I have two sets duallys L.E.D lights .. One pair on windshield & one in bumper ... Other than that my electrical is all stock & I have them wired separate & off the battery ... I've had this setup since April or may - no probs ... Today went out to get it & dead .... Not even a click dead .... I jumped it & at idle battery showed 14.60V which I believe shows a operating alternator correct ? And off battery shows 12.80 ... Which is a good battery correct ? .... Any ideas what's going on ? Nothing left on ... Let run for 10 mins shut off & right back to dead ... The dome light flickers the whole time running but the numbers should be normal ?
Your battery may simply have a dead cell. My stock battery in my '12 died after only 18 months and I had the dealer replace it under warranty. Offloading (and vibrations) kill regular batteries pretty easily.
Thanks e-man ... Did you have any aftermarket accessories ? I'm afraid they're gonna tell me too bad ..... My LEDs are at fault & they won't do anything .... Guess I gotta try . Just seeing if anybody else has been here . Your symptoms the same ?
Heeeaalllllp !!!!
Originally Posted by JackDANJK22
(Post 3984743)
For me, my Jeep started fine in my garage. Started it up and drove 15 min to drop my boy off at school. Dropped him off and got back in and it barely made a click. Called my wife to come jump the battery and drive it straight to the dealer. They put the battery on their meter and said it was one of the "worst" dead battery's they've seen. Said that the vibrations from offloading likely destroyed one or more of the plates in the battery. |
When you start adding lights and winches and whatnot, it might be a good time to consider a battery upgrade to something that will handle the offroad abuse and the extra components better.
The Sears Diehard Platinum has a fairly good rep, as well as several other brands (mostly ones I haven't heard of outside of those threads, but people in the know are giving them good reviews so they are probably worth checking on also). Read through a few of the aftermarket battery threads and see what you think. |
Agree with nthinuf 100%. My next battery will be a Die Hard Platinum or other AGM battery. I only went with another stock one since it was free :)
Originally Posted by nthinuf
(Post 3984754)
Well ! Thanks e-man ! You are the man .. Took it up to autozone just to see they're check & bad battery ..... At this point I agree with you & considering just upgrading battery's or do the dealership hassle for free ... Nothing good on optima ?
It happened to me that fast aswell ! Kinda crazy ! |
Back in the day, Optima was a great option. But, if you find and read through a few of the battery threads I mentioned, you might find that Optima isn't one of the ones people are recommending these days. For whatever reason, their reliability seems to have taken a hit.
From what I have read, the diehard platinum is the top choice for most people. Probably just due to its availability at more local stores than the other top recommendations. |
(Post 3984859)
From what I have read, the diehard platinum is the top choice for most people. Probably just due to its availability at more local stores than the other top recommendations. I myself just got an optima from autozone, works great. Only thing I didn't like about it was the sticker that said made made in mexico... can't we make anything here in the states/Canada anymore like this? |
