JK Electrical, Lighting & Sound SystemsBulletin board forum regarding topics such as stereo head units, CD players, MP3 players, speaker systems, amplifiers, hardmounted GPS devices, computers, headlight upgrades, fog lights, off-road lights, general wiring and anti-theft devices.
If it were me,and if the battery was more than 3 yrs old I would buy a new battery just as preventative maintenance. Then put the new battery in and start the Jeep. If you are not getting around 14 volts with the Jeep running then the alternator is likely bad (assuming all connections are tight and in good condition).
Auto parts stores will test the alternator. They can test in or out of the vehicle but my understanding is that the in vehicle test is more accurate if you can get it up to the store. With the events going on, I'd call ahead and ask that they still perform the service.
I replaced the alternator after it tested bad. Unfortunately, the symptoms remained. I took it to my mechanic after that. The pcm was not allowing the alternator to charge.
My son recently had a similar issue on a Hyundai. In his case, the pcm was not bad. It was a faulty wire from the battery to the pcm. The mechanic replaced the cable and all is well. It is just a small wire that tells the pcm what the voltage is so the pcm can tell the alternator what to do.
Hello,
I had an issue with low battery its shows 10.5 but can start car, the issue come when bolt light get on with Traction control with two code P0300, P2167
I have clear codes but keep coming back I have replaced the pedal sensor Acceleration but still the same do you think battery with low voltage can cause the problem
Hello,
Low voltage can cause a lot of strange behavior. My instruments went crazy when my battery died.
