help with dead turn signals
Old Jun 24, 2008 | 07:55 AM
medbender's Avatar
Default help with dead turn signals
all the sudden, no turn signals. everything else works fine including the hazards. all bulbs and fuses are good. any ideas?
Old Jun 24, 2008 | 08:00 AM
Offroadme's Avatar
Good news:
i remember somewhere someone said that the plug under the dash had some loose. they had taken it to the dealer and thats all it was... i would look under the dash see if the plug is loose...
Bad news: there was another post somewhere that a fellow jeeper had to get the gauge cluster replaced. this will all be covered under warranty. so don't worry.
Old Jun 24, 2008 | 08:05 AM
medbender's Avatar
I just hate going to the dealer. i'll check under the dash first. thanks for the info.
Old Jun 24, 2008 | 09:02 AM
artpics's Avatar
My indicators only worked one side it would turn on but not off when turning.
They had to replace the cluster but had to take the airbag out to do so it took them 4 hours
Old Jun 24, 2008 | 09:11 AM
medbender's Avatar
i get no light whats so ever. it happened after wheelin so im hoping its just a loose connector. i peaked under the dash but theres not a whole lot going on where i could see.
Old Jun 25, 2008 | 07:11 AM
medbender's Avatar
took it to the dealer who found a short in the turn signal switch at the steering columb. now it s all good.
