JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   JK Electrical, Lighting & Sound Systems (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/)
-   -   help with dead turn signals (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/help-dead-turn-signals-45376/)
medbender Jun 24, 2008 07:55 AM
all the sudden, no turn signals. everything else works fine including the hazards. all bulbs and fuses are good. any ideas?
Offroadme Jun 24, 2008 08:00 AM
Good news:
i remember somewhere someone said that the plug under the dash had some loose. they had taken it to the dealer and thats all it was... i would look under the dash see if the plug is loose...
Bad news: there was another post somewhere that a fellow jeeper had to get the gauge cluster replaced. this will all be covered under warranty. so don't worry.
medbender Jun 24, 2008 08:05 AM
I just hate going to the dealer. i'll check under the dash first. thanks for the info.
artpics Jun 24, 2008 09:02 AM
My indicators only worked one side it would turn on but not off when turning.
They had to replace the cluster but had to take the airbag out to do so it took them 4 hours :sad2:
medbender Jun 24, 2008 09:11 AM
i get no light whats so ever. it happened after wheelin so im hoping its just a loose connector. i peaked under the dash but theres not a whole lot going on where i could see.
medbender Jun 25, 2008 07:11 AM
took it to the dealer who found a short in the turn signal switch at the steering columb. now it s all good.
© 2026 MH Sub I, LLC dba Internet Brands
