hid debacle
I don't know what car is pictured above but those are not very good projectors. S2000/TSX/FX/etc are some of the best and they have SHARP cutoff with up kicks on the right. They are lower on the driver and higher on the passenger. The hot spots on the Non-Projector HID in the 2nd kit is horrible. That will definitely be very bad on on coming drivers. Put them into a raised vehicle and it is only multiplied.
I would not suggest putting HID's in the stock reflector assembly. Although they don't scatter light that bad (compared to some of the pics i've seen on the web), they still leak light above the cutoff line more than halogen. The above's projector setup is mine, and they're up for sale because I made another set. Contact me if you're interested.
Now, to really answer your question, make sure you're using a relay setup. You need to add a capacitor to your harness to keep a constant current to the relay.
http://store.theretrofitsource.com/p...d29e6c5dc9ee85
If you use HIDs, go with a proper retrofit please. I get sick of being blinded by cheap reflector housings holding HID bulbs.
On my WRX I modded my stock reflector cutoff shields and it produced a sharp cut off, but poor optics. Then I went to S2000 projectors and WOW!
And speaking from personal experience, I refuse to use bi-xenon "moving capsule" HIDs since they always crap out on me...
The aftermarket Hi/Lo kits tend to wear out quickly in terms of the little moving 'shield' to give you that bi-xenon type experience.
That's what I was referring to... And I did those on my Cherokee and they crapped out in 1 month. Warranty was honored and then it crapped out 2 months later and I was like screw it and went back to halogen. Also - HID doesn't melt the snow we get here off of the headlights.
If it is an OEM moving sheild like a moving mirror, then fine.
I've had the VVME HID H13 kit for 3 months without any issues.
My stock headlight housings suck but I have not been flashed and the light pattern is the same as stock, just brighter.
I am going to swap to a better housing (Hella or Cibie H4 housing) and see how that works.
