HID Replacement kit for 2012?
Old Dec 6, 2011 | 09:13 AM
jkellington's Avatar
Originally Posted by firefighter53111
I didn't replace the stock housing just adjust the lights. If you have an 11 or 12 you need the 55 watt kit for the can-bus system. Make sure you also get the hi/low kit.
OK, I'm thinking of going with DDM the 6000K 55W Hi/Lo kit for the headlights and the 5000K kit for the fogs, considering they're plug and play and wicked cheap.
Anybody out there against this, or have a better solution?
Old Apr 5, 2012 | 08:50 AM
DavinGee's Avatar
I have hi/low h13 55 watt kit from DDM for headlights and 35 watt kit for the fogs. I've had no problems.
Any updates on these kits? Have you had any problems with the headlights? Any issues with the fog housings melting?
I'm looking at installing the 55w HIDs in the headlights but not sure what to put in the fog lights yet. I would like to keep the stock housings.
Hopefully I receive some feedback.
Thanks!
Old Apr 6, 2012 | 12:46 AM
rickyj's Avatar
I would go with the 35 watt kit for the headlamps. Any search on here will show you that I am very pro HID, but the 55w is just plain too much light. Works great on rural roads - but if you do most of your driving in the city, get the 35 watt kit.
The 55w is not overly obnoxious, and I have passed at least a THOUSAND police officers with my 55w kit ON (as in at night) and not a one has had a problem with them. 99% of the time, people do not flash either.
But 55w is just too much light for every day. To do it again, I would probably go for the 35 watt on the main lamps, 55w on the fogs, and a 100w kit on the off roads. Now I have 55w all over.
Old Apr 6, 2012 | 03:54 PM
DavinGee's Avatar
Have the HIDs melted the fog light housings?
Old Apr 8, 2012 | 12:41 AM
rickyj's Avatar
Absolutely not.
HID by wattage produce LESS heat than incandescent - they take the heat and make it light.
I have heard of HID melting housings, of ALL those stories I have heard it was a 55w HID installed in a 25-35 watt housing.
My brother had issues, but it was the same overpowered lamp story.
I have run my HID, both stock and fog, for hundreds of hours - no issue.
Stay rational, and you will be fine.
Old Apr 8, 2012 | 07:14 AM
anthonys88's Avatar
I would seriously consider the rebel offroad hid kit made just for the jk... They have a+++ customer service and the kit is awesome!
Old Apr 8, 2012 | 10:42 AM
Cpl_Punishment's Avatar
Any update on this? I just ordered my 12 Sahara and would like to follow suit here with the OP.
What did you order?
Any issues?
Any photos?
Old Apr 8, 2012 | 08:14 PM
DavinGee's Avatar
Originally Posted by rickyj
Absolutely not.
Thanks! I'll look into ordering the 35w HIDs for the fogs then.
Old Apr 8, 2012 | 08:52 PM
firefighter53111's Avatar
Becareful with the HID fogs. I have them in mu 2011 and they're melting the housing. I have the 35 watt kit.
Old Apr 9, 2012 | 04:18 PM
DavinGee's Avatar
Absolutely not.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=301485"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=301484"/>
Okay, so I'm being told that the 35w HIDs will NOT melt the fog housings, yet there is proof that they DO melt the housings.
So I guess I'll look at other options for the fog lights.
