HID suggestions
Old Feb 20, 2012 | 09:41 AM
rlfracing's Avatar
Default HID suggestions
Im wanting to upgrade my headlights and fogs to hid. But not sure what brands to look at and stay away from. I do want hi lo beams for the headlights. So what does everyone suggest?
Old Feb 22, 2012 | 09:41 PM
rickyj's Avatar
I would go with VVME, and specifically one of their CANBUS kits - you will have to call this order in or ask a rep online as the CANBUS ballasts are not listed.
I have found the beam pattern to be very acceptable with the stock housings, and apparently so has oncoming traffic and law enforcement in every jurisdiction I have been in.
If you do a search, you can find plenty of information posted by me showing that HID are legal in most areas, and I have posted beam patterns similar to factory HID patterns.
Worn out on this battle however, so I won't repost.
If you want more light, HID is the only way to go. Incandescent bulbs are a very old technology - and although they have been improved significantly, they are still old and outdated.
If you want to see for yourself, order a VVME or DDM kit for your fogs and install them. The fogs do not need to be canbus ballasts, the headlamps should be.
