High Beam Wire to tap into??
Old Sep 3, 2007 | 07:49 AM
hotdogging's Avatar
Default High Beam Wire to tap into??
I'm trying to wire my auxiliary lights but need to tap into the high beam wire. I tried the search function but came up with mixed results.
There are 3 wires running into the drivers side light, a brown one, a white one with blue stripping, and another white one with green stripping. Does anyone know which one I need to tap into to? My plan is to turn on the high beams and then turn on my auxiliary lights if need be.
Thanks in advance.
Old Sep 3, 2007 | 08:39 AM
yellowjeeper85's Avatar
you could test them with a multimeter, or if you have a light laying around, ground one side, and turn your high beams on, (with the headlight removed) plug the other wire into the pins on the jeeps connector till it lights up, when it does, thats your high beam wire.
Old Sep 3, 2007 | 02:59 PM
hotdogging's Avatar
FYI-
High beam wire to tap into was the white with green stipping.
