How to wire kc 8 pro6 gravitylight to spod for 2016 jk
This is direction to a single switch that came with kc lights
ANY BODY NO HOW TO WIRE TO SPOD INSTEAD OF WIREING TO A SINGLE SWITCH DONT WONT TO DO ANYTHING WRONG SINCE THEY AREN'T CHEAP DONT WONT TO MESS THIS UP
Aside from grammar and spelling, LED's are (but definition) one way only. You cannot mess them up. The directions there should be the same for your SPOD switch.
Wiring diagrams are always a bit intimidating for non-electrical minded folks. The beauty of the sPOD (or other like items) is how simple they make it. All you really need to do is determine the ground wire and what will be the hot wire heading to the lights. Those are the only two things you need to hook to the sPOD. The sPOD is doing all the relay work for you. The only other thing you'd need to do is make sure you have the proper fuse in that specific sPOD bay.
I don't understand why you're planning to use the relay that came with the kit. The sPOD has a relay already.
