JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   JK Electrical, Lighting & Sound Systems (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/)
-   -   hurst shifter with overdrive controle. (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/hurst-shifter-overdrive-controle-108489/)
guybergeron Nov 14, 2009 12:09 AM
hello jeepers. ok this morning (4:05 am ) i was thinking about doing something with a hurst shifter for a automatic transmision. i would like to install a t handle with a button on the left. the button would control the overdrive. im realy tired to alwase have to stretch and try to find the damn button and try to watch for trafic on the hyway. how can i i do that. im not realy good with whires but i think i can manage to do that. any inpute would be realy apreciated and i think that im not the first to think about that.
have a good day.
guybergeron Nov 14, 2009 09:54 AM
well its ben 10 hours since i posted this tread... anyone have some idea to help me ?
redrunner Nov 14, 2009 12:56 PM
Here is what I did, you could adapt a new button anyware and skip the default overdrive off part. Hope this gives you ideas.
http://home.comcast.net/~kingslea1/Jeep/ODMod.pdf
AK4Dave Nov 14, 2009 01:06 PM
Wow............VERY nice write up...!!!
guybergeron Nov 15, 2009 01:27 PM
all right!!:thumbsup: thanks alot redrunner.
guybergeron Nov 20, 2009 12:01 PM
ok so i tried to understand but i am not realy good wit electrical blue print... is is possible to mount the overdrive button to the stock shifter in a way?
redrunner Nov 21, 2009 05:14 AM
Electrically, it is certainly possible as it involves only two wires and a momentary switch. What you have to consider is how you will make the mod to insure the wiring won't fail due to shifter movement and how you want it to look when you are done (e.g. how you want to conceal the wires).
To me, mounting the OD switch on the shifter is still a reach, but if that is what you want, go for it.
lbwhotrod May 25, 2010 08:47 PM
Hey thanks redrunner your post helped me alot with switch problem.
septonic May 25, 2010 11:26 PM
You should put the od switch on the side of the steering wheel and, treat it like a nos button. :D
redrunner May 27, 2010 01:46 PM
Originally Posted by BryGuy (Post 1707774)
Holy Crap :eek2:..... that's some write-up :thumbsup:
Where did you get all the schematics from :thinking:
Honestly I can't remember exactly. Some I probably made, but the stock wiring methodology came from the service manual.
© 2026 MH Sub I, LLC dba Internet Brands
