iphone songs playing to fast on mygig, why?
Yesterday I discovered that on my 2011 I could play streaming audio from my phone and it worked pretty good. I went home and bought a few driving songs and tried to do it today and all the songs are playing at a super fast speed. I works on the iphone just not through the mygig. I did an update on the phone when I bought the songs on itunes to version 4.1 from version 3.1 something. Any advice would be helpful.
(thought I read about someone else having this problem but I couldn't find thread) |
Mine does the same thing, sometimes.. if I turn everything off and start over it works fine.
I haven't found out what causes it to act like that but I would like to know if anyone has a solution, I grew out of listening to the Chipmunks a long time ago. |
I have no clue how the iphone works with the My Gig, but I had an issue with songs playing too fast from the iphone being connected to the stock radio via a Aux jack.
The culprit was the Aux cable. It wasn't connecting right and it seems that the iphone can sense when it is connected to it. It would "freak out" and play songs too fast and even skip songs until I bought a new cable. Since then, no more issues. |
How are you connecting to the mygig
This same thing happens on my 2011 Rubi and iPhone 4 version 4.01. I haven't found a fix yet. Instead, I just plug it up via the usb in the center console, and that works better anyway. Lets you see all the artists and songs and shit on the screen.
I was connecting with the blue tooth. If I turn it all off and then back on, it seems to work but I can't see the songs. It will play the next song but I can't sort by artist or anything. As soon as I touch the phone it goes crazy. I need to use the phone to find the songs i want to hear and that's with it screws up. I will try the cable today and see if that works any better. The crappy thing is that it worked before I updated the phone!
I tried to use the USB port you talked about and it can't find the files! It used to work. I don't know, this is way over my tech level!
I used the USB in the console today and it works fine but its slow, it takes a while for it to update and find everything, its much faster via bluetooth but its not very solid.
Originally Posted by RPO_Z06
(Post 1907625)
I used the USB in the console today and it works fine but its slow, it takes a while for it to update and find everything, its much faster via blue tooth but its not very solid.
There is a small button on the now playing screen of the iphone that usually says "1x". It is really easy to hit that button and make it "2x" or "3x" with out noticing, I've done that before....
