Not sure on that. The way to test the presence of the pulse is like one of the others posted.
Key On / Engine Off - should be full 12V Key On / Engine On - if pulse then you'll get a low voltage on your meter / if not pulse then you'll get a full 12V |
Originally Posted by 14Sport
(Post 4155319)
The fogs are definitely PWM. I don't know about the parking lights.
Guess I'll have to go out and put a duty cycle meter on the fog light wires. |
Originally Posted by ronjenx
(Post 4155384)
The 2008 service manual says the TIPM sends PWM voltage to the headlights. When it describes the fog lights, it say the TIPM sends battery voltage to the fog lights.
Problem solved
Problem solved! :rock:
When the Jeep was off, the LED lights worked fine. As soon as I turned the Jeep on, they flashed a couple of times, then went out. It seemed like the PWM was detecting if there was a light on the end, didn't detect one and then shut off and turned power off to the line. I added resistors to each headlight harness to 'trick' it into thinking there was a bulb on the end instead of the LEDs. Now, when I turn the Jeep on they no longer flash. In addition, they have stayed on ever since without flickering or anything. Seems like problem solved. Only problem, those resistors are really *$%&_* hot. I need to find a place to mount them so they don't melt anything under the hood. |
Originally Posted by scalpel_shredr
(Post 4155654)
Originally Posted by jedg
(Post 4155656)
Good deal. So that's a drawback of that SMS box perhaps. The harness I use plugs into one of the H13 headlamp plugs and sends that signal to the capacitors and then to the relays which activate the circuit that ties into the H4 plugs and uses power from the battery (with a fuse) directly.
Did you build your harness yourself or buy it? If you bought it, can you send me a link to what you used? |
(Post 4155667)
Actually....this is bypassing that SMS box altogether. I think I may just take that box out actually since its working without it. No need to risk screwing things up again.
Did you build your harness yourself or buy it? If you bought it, can you send me a link to what you used? I built my harness. I use a Bussman fuse panel to run my fuses and relays. The only items not in the Bussman is the diodes and capacitor I used to get the flicker out. |
(Post 4155654)
(Post 4155750)
Get a resistor that is rated for a wattage higher than the circuit is seeing.
Did the resisitors take care of the problem for you? I am having the same issues. Also mine is a 2007 Sahara Unlimited.
