JW Speaker Help
JW Speaker Help
Just received a pair of JW Speakers as a gift and having a little trouble with the wiring of them. I have been searching around to find a wiring diagram but can't find any like mine. The wires have 91 17 18 labeled on the metal plates don't know if that helps. I have the truck lite antiflicker harness so I'm trying to wire the jw speaker into a h4 plug, but can't figure out which wire is which
but these are 24v LED lights?. They should work either way. If they run at 24v they draw less amps. They should run at 12v will just draw more amps.
Have you tried checking out their website for a schematic?
I would cut off the connecters and make my own by finding out which are ground and which are the low and high beam. Them buy a generic H13 plug and splice them in.
There may be a plug and play adapter...but who knows how long that may take to find.
Your lights won't work unless you use a step up converter. My first set of truck lites were for a 24v system and had to use a step up converter. Since then I've switched to the newest version which are a 3v to 36v application and I no longer needed the converter.
You are looking for something like this...
http://www.amazon.com/Converter-Regu...iglink20367-20
I would check directly with JW Speaker first. Also have them verify those would only run at 24v...some leds will accept 12 or 24 volts
I see.... couldn't he wire in a relay with true 12v and just trigger it with the factory wires in that case?
