Kc slimlites long range
So I'm wanting to put a set of slimline long range KC's on my front bumper. If I like them, I may consider moving them up to windshield mounts and buying a set of fog lights for the front bumper.
If I do that, is there a simple way to swap the physical light out without having to rerun all the wiring harness?
Pretty simple issue, but I don't know if I am going to want to move them, but if I do, don't want to have to "unrun" the harness and rerun a new one for the same brand foglights...
Any thoughts would be greatly appreciated!
Originally Posted by isolated1523
All of my KC lights lately have come with 6" leads coming out of the lights, and a connector to attach the wiring harness to. So yes, you could unplug/unbolt and move them.
-Adam
-Adam
I have two of the KC rocker switches mounted in the center dash, just under the power window switches. I have room for a third (when i find something else to add lol).
I am out of town so cant get a pic til thursday morning, sorry...they are mounted horizontally in line, rocking the switch left turns it on, right off. Room for 3 switches in between the center air vents, below the power window switches, if that makes any sense. Now, i have a 2 door, so i dont know if there would be room there with the 4 door power window switches (or the new 2011-and up dash, for that matter)
-Adam
-Adam
I did this, https://www.jk-forum.com/forums/jk-e...ch-pod-229022/ .Since you maybe looking to go with more lights you should think about doing it.
Im thinking about mounting the switch underneath the air vent by the driver door. Theres room for at least 2 switches there. Will post pics when done, only if it looks good that is.
