kc windshield light brackets
Old Dec 3, 2008 | 04:03 PM
kflash's Avatar
Default kc windshield light brackets
My brackets arrived. Are you all installing them directly against the paint? I was thinking some sort of gasket should go between to allow for a clean removal if ever the need.
I also received the grille covers with the big white KC on the front. I was kind of hoping for the smaller KC that I have seen on others. Does anyone know if this is their new style?
Old Dec 3, 2008 | 04:42 PM
08{GA}RUBICON's Avatar
I just used double sided foam and cut them to cover the mounting side that was against the paint.
Old Dec 3, 2008 | 08:30 PM
SFD1248's Avatar
I bought a cheap gasket kit and cut it the same shape as the bracket. Works well
Old Dec 3, 2008 | 08:35 PM
Leonard Massi's Avatar
Exclamation Windshield mount
depending on the lights you're using you may regret the windshield mounted setup, I got so much glare off the hood. I stopped using them, bought some HID's and moved them upfront to the bumper. " I CAN SEEEEEEE!!!!!!"
Old Dec 3, 2008 | 08:39 PM
SFD1248's Avatar
yeah I get a little glare with the kc130s but I have mine pointing outward a little and it helped alot.
