LED Bulbs - Resistor Installation Write-Up
So I bought some smoked taillights and wanted to put some LED's in the housing... The quick bulb flash with the turn signals drives me crazy... HEre is how to install the resistors to make that go away.
Bought bulbs from LED Lights, Bulbs & Accessories - SUPER BRIGHT LEDS
Ordered two (2) of the 3157-x45-T in Red. They are "Dual Intensity 45 SMD LED Tower"
** Superbright makes a bulb witht he resistors built in, but the DO NOT fit the Jeep housing. **
I also ordered two (2) of the RL-650: Tail Light Load Resistor Kit
Bulbs: $24.95 Each
Resistors: $4.95 each
In the taillights, the main bulb has three wires coming out of the housing:
Black
White w/blue stripe
White w/yellow stripe
We want the black (ground) and the one with the yellow stripe - this is the brake wire.
Using the supplied connectors, clip one end of the resistor to the black wire, and the other end to the white/yellow wire.
I used a small wire tie to keep the resistor from flopping around inside the fender.
That is it!!! No more fast blinking.
Bulbs: $24.95 Each
Black
White w/blue stripe
I just tried to do the resistors on all 4 corners but for some reason I can't get the left front to work. It is some how feeding the parking lights so when that turn signal is on all the parking lights flash too.
I had the same problem, the front corners don't work with the resistors. Only the tail lights work.
I wired up an HID kit to my headlights, and now they won't come on. Where. I unlock my jeep with the remote, they work. But as soon as I turn on the engine, they become intermittent. Either one will come on or none at all. I have a 2010 2dr,with a pioneer 6400bt radio. Idk if the radio install might have set it out of whack, but it didn't start doing this until 4 days after I installed the new radio.
Bulbs: $24.95 Each
Black
White w/blue stripe
Bulbs: $24.95 Each
Black
White w/blue stripe
The fast blinking don't bother me any more.
So if I cause a stroke or a seizure, meh....
