LED Lighting Mod... fuse keeps blowing?
Old May 2, 2011 | 10:06 AM
TURTLECON's Avatar
Default LED Lighting Mod... fuse keeps blowing?
I did the LED dash lighting mod where I tapped into the A/C controls dimmer wire and cigarette lighter ground (driver's side) to install an LED strip in my dash panel. Everything works perfectly but I keep blowing the 20amp M5 fuse. This is the 2nd time this fuse has blown since I've done the mod a couple months ago. Anyone have any idea why this could be happening?
Old May 2, 2011 | 03:57 PM
TURTLECON's Avatar
Bump for an answer?
Old May 2, 2011 | 04:52 PM
Alec's Avatar
My first thought would be a bad connection that is causing higher resistance, or bad ground as mentioned above.
Old May 2, 2011 | 05:26 PM
TURTLECON's Avatar
It's a 6 led strip, like you get at PepBoys or Autozone. I think you're right though... if I'm only grounding to the cig lighter black wire, then that might be the problem. Is there bare metal somewhere behind the dash console I can ground to?
Old Sep 3, 2011 | 08:59 AM
4JEXEP4's Avatar
Never and I stress never tap into wires behind the dash. The Jk has a canbus system and you are always going to have problems unless you use a special tap for that system. Like this http://www.quadratec.com/products/96080_98.htm
You should always run dedicated power for any accessory you run.
Old Sep 5, 2011 | 08:00 AM
TURTLECON's Avatar
You're probably right, but hundreds of JK owners have been tapping into the electrical in various places without any problems.
