Light wire routing
Old Mar 18, 2012 | 11:16 AM
Alabamacoalminer's Avatar
Default Light wire routing
M installing a set of windsheild lights on my 08 jku I've hit a snag and can't find a place to come in the cab with the wireing for my switch any suggestions please ?
Old Mar 18, 2012 | 12:16 PM
Matthewd5's Avatar
Go read the thread dually d2 install, he shows pictures and gives narration on how he did it, I think it's exactly what your looking for
Matthew
Old Mar 18, 2012 | 12:30 PM
conifers4's Avatar
Remove the plastic ends on the dash board (they pop right off). You will see a circular hole that is filled with an expandable foam type material. Use a wire coathanger to punch a hole through it and you have instant access.
Old Mar 18, 2012 | 01:34 PM
Thanks for the help I went and found the write up on the d2's that really helped alot! Thanks again!
