lights!!!!! help
I have the Hella Black Magic's and have to say they are not bright at all. I even went as far as changing the the light bulbs to 100w from the 55w for the 1000's and they are a little better.
I get tons of compliments, I really don't like the light output.
If you read the descriptions on both they are DOT approved DRIVING LIGHTS. most brighter light say not approved for highway or OFFROAD USE ONLY.
But just An idea I did find an HID conversion kit that states it will work. so i might be going that route.
Hella 4000's, choose either driving or Euro beam. On the trail, it's slower so I have the cornering beam which is more of a floodlight with a 130w bulb. All steel construction and very sturdy mount.
i have been suggested the lightforces by multiple people now. and i would like them too...but its hard to justify that to myself when i am going to be running 7 lights plus fogs plus stock driving lights
I installed the Black Magic 500's on my windshield and they are not a bright as I anticipated, however they make a difference. I don't know if I'd choose these again though; unlike the KC's i've had in the past, you cannot replace the lense if damaged, you have to replace the entire assembly. With the 1000's it's not as big of a problem because they're offered individually, the 500's are only sold in pairs. All in all they were he easiest install i've ever done, and I'm content for now. I'll post a pic with the lights on.
If I can make a suggestion I'd go with the clear fog lamps from eagle the are legal and give good light, the run a pair of kc driving lamps slim and another pair of kc long range that set up hasn't let me down
If you are going to use anything bigger than 55w I wouldn't waist your time with the factory fog light kit my jeep wouldn't handle the extra amperage that was drawn from the lights, plus that switch turns off the fogs when the high beam is on. I think you would be better off with a separate switch/relay after market kit
