Multiple component power issues
Old Sep 27, 2013 | 05:26 AM
JkHauler's Avatar
Default Multiple component power issues
So I'm running into a slight power problem. I have the following one a switch panel:
  • winch
  • a-frame lights
  • rock lights
  • air compressor
  • switch lights
I'm using a bussman relay box to source power to everything and the box is hooked directly to my battery. I find my jeep with a low battery on more than one occasion. Should I move the bussman power source to a ignition on spot in the fuse box or is there other options that will allow me to cut power when I dont need it?
Old Sep 27, 2013 | 08:45 AM
toolow262's Avatar
Veteran: Coast Guard
I would install a high amp relay between your battery and relay/fuse box. Power that relay with a switched power source from the Jeep fuse box to alleviate the need to put in another switch in-cab and to remember to turn it off. When the Jeep is cranked it will energize your switch panel.
