Just completed the map update. The system info is:
App 2.404 Gracenotes 4620 Database R2 - N 1245 3.7.0 SDS 170901 Sys 6816 006 3.5 Hope that helps. |
Originally Posted by geospyder
(Post 3720848)
Just completed the map update. The system info is...
Database R2 - N 1245 3.7.0 ... Thanks for posting what you found! |
(Post 3720581)
Found out what I'm missing in order to have uConnect - an OEM microphone. Sounds very simple to install. Manana.
Originally Posted by jwilson2598
(Post 3721223)
Once you have the mic, you'll also need to go into the engineering menu to turn it on. Press Seek Up + Seek Down + Menu at the same time, and then the Engineering menu will open. Go down to page 4 or 5 I think and you will see a menu item that says "Enable JK HF+VR". Push that button, it will then change from Enable to Disable. Exit the menu with the menu button on the radio, you should now be able to push the UConnect button and be greeted by the UConnect prompts.
Originally Posted by ckatz88
(Post 1977389)
I am hardly able to use the nav in my Jeep. Most address arnt even in the system and 80% of the time, when i do actually find the location Im looking for in the POI, it trys to send me to one 500 plus miles away. I think an update could help, but dont want to spend the money and be dissapointed.
Sent from my iPad using Tapatalk |
I called today and they didn't give me any more information on the 3 digit database code.
