Need help with KC Daylighter install...
Old Aug 14, 2007 | 09:01 AM
shredX's Avatar
Default Need help with KC Daylighter install...
Need help!!!
I installed my KC Daylighters and can't get the lights to come on. I read and re-read the directions. The little green LED on the switch is turning on, but nothing from the lights. I grounded the lights to the windshield mounts and the switch to some bare metal under the dash.
Any thoughts? Am I missing something easy?
Thanks
- Andy
Old Aug 14, 2007 | 09:09 AM
Piginajeep's Avatar
Originally Posted by shredX
Need help!!!
Thanks
- Andy
did you ground the switch? and the ground at the battery?
Old Aug 14, 2007 | 09:11 AM
HappyCurmudgeon's Avatar
Eternal ***erator
Dont want to sound a smart-ass here... but if there is an inline fuse in it... is there a fuse in the holder? if so, is is it a good fuse?
Dont ask me how i know....
Old Aug 14, 2007 | 10:39 AM
shredX's Avatar
The switch is grounded. My windshield mounts are painted and that's where I grounded each light. When I get home I'm going to try to ground the lights somewhere else. I forgot that the paint acts as an insulator.
Thanks....
Old Aug 14, 2007 | 10:40 AM
shredX's Avatar
Fuse looks good.
Thanks!
Old Aug 14, 2007 | 10:44 AM
armycop's Avatar
Thanks....
In the engine compartment, I spliced a bigger O shaped connector on the end and used the actual engine compartment ground for a light ground. Inside the dash near the driver's door, there is a small bolt that I used as a ground. The panel removes easily. That layer of paint is what is messing your connection up! You need bare metal.
Old Aug 14, 2007 | 10:47 AM
Piginajeep's Avatar
Thanks....
I went right to the battery with the ground on the harness. that way i know its a good ground.
Good luck, and let us know!
Old Aug 14, 2007 | 05:23 PM
dsp's Avatar
dsp
I did the same thing. when i put lights on my yj, no problem using the bracket as a ground. With the JK, no ah ah. I just ran a ground wire into the engine compartment and attached them to the ground straps.
Old Aug 15, 2007 | 07:02 AM
shredX's Avatar
Update....
Neither of the lights were grounded properly. I lengthened the ground wires and attached them to the inner fenders where some other wires were already grounded. Everything works.
Thanks for the help!!!!!!
Andy
Old Aug 15, 2007 | 07:31 AM
armycop's Avatar
Update....
Andy
Glad to hear they are working. Mine are bright as hell, make the hi-beam headlights look dim! I want to mount a set in the spare tire to blind tailgaters. (or to see what is behind me is the story I tell the cops)
