Need help with OBD2
Need help with OBD2
My plug got destroyed and I don’t know the sequence the wires go into I bought a new plug from Amazon and I don’t know what goes where can anybody help?
I have a '13, so not certain it is the same, but my OBDII clips broke so I can easily look at mine tonight if I remember or you remind me. It's easy for me to pull it out of the retaining bracket and snap a pic so you can see the colors and placement.....again, if it remained the same over the years.
Or...maybe @ronjenx might have this info possibly.
I'm battling the same issue with OBD2
Here is what I have found for the JKU wiring diagram for the OBD2 data port connector. It only has 5 wires. My question is... What is the part Number for the actual OBD2 pigtail connector? Mine is trashed and I would like to replace it. I have tried to search through Mopar parts sites and can't find it. Yes, I have tried to search the number on this diagram and it appears to be discontinued. I find that hard to believe.
and i apparently forgot to snap a pic. if you still need help with this let us know.
