Need a pinout from the FSM
Can someone with the FSM look up the pin out for the "Dynamics (ESP)" sensor?
Might mention pitch/yaw. I need the wire colours and their function.
I'm pretty sure the wiring for that sensor is what you JK guys tap in to, to disable ESP/TCS.
I'm trying to do the same to my KJ.... one of the how-to threads mentioned the wire was near the ebrake, KJ's yaw sensor is next to the ebrake and uses the same colour wires, so if I can get a JK pinout for that sensor I'll know if I can use the same method in the KJ.
