New CHR 550 Lockpick install
Need a little help. Pulled my old Lockpick out to install the latest version. Step 2 tells me to unplug the white connector from the back of my MyGig radio and install the lockpick harness. Problem is, there is no white connector plugged into the back of my radio. I thought possibly it had been tucked away in the dash somewhere, but I have torn apart my Jeep looking for this mysterious white connector. ANY help or thoughts would be greatly appreciated.
I installed mine last week and it didn't have the white connector from the factory either. I believe that the white connector is for the factory entertainment system found in other vehicles. I still plugged the white connector from the lock pick into the mygig so that the video sources attached to it will display on the head unit. Be sure to turn on and test your mygig before putting the dash back together. I had issues with some of my speakers not working due to bent pins in the harness. Easy to fix, but wish I had checked before putting the dash back together.
I just put mine in today too, I don't think the wranglers have the white plugs, mine didn't either.
Not to hijack totally, but I'm having the speaker issue too. Where were the wires bent on yours? This seems to be a common issue.
