No Power on Radio/AMP and Inlight - help!
Hey Guys
i have a Problem. I replaced my original Headunit to a XTRONS Headunit (works well) and yesterday i added the amp (ETON DSP 8).
I made a special adapter-harness that i can use the original whires and plugs without changing anything so i can easy replays everything and itīs original again.
Anyhow- i made something wrong. My Radio is notworking anymore and my inlights are also dark. Checking the Voltage at the radio-connector - it says 0V.
So i checked the Fuses (M12, M10 and M11), all fine. Now i checkt the Voltage between the Fuse-Socket an the ground of the Car - also 0V. So there must be some kind like a pre-Fuse wich may be broken?!
Has anyone an idea?
Thanks for helping!!! Itīs soooo quiet an dark in my car.....
Has anyone an idea?
