Which OEM NAV unit should I look for when replacing RES?
I have a 2012 JKU Sport. It has the Connectivity package and Uconnect, SAT, etc.
I want to replace my stock 130 RES with one of the NAV units.
SO, RHR, RHB, or RER?
I know it must be high speed. I have read that there may be a difference in the antenna for the NAV and SAT in one vs. another. For example, one may use my existing SAT antenna for both NAV and SAT, but another may not, and i will have to add the antenna.
I would like to keep it as simple as possible, and if I could just plug and play without having to add anything, that would be ideal.
Has anyone already tackled this or know enough about it that can give me some advice?
Hi all I'm now very confused. I thought the RHR was the only one that would work on a 2012 wrangler. What is the difference between the RHB and the RHR? I know I need a high speed. But, what is the correct model?
Both the rhr and rhb are basically plug and play. The rhr has Uconnect built-in, so that would make your previous system redundant. That also means you would need to rewire your microphone or install a new one....and the accessory USB that currently runs into your Uconnect module. The rhb would be the easiest to install and you still utilize your current mic and Uconnect system (that's what I did). There are differences in the feature set between the 2 radios though, so you may find it worth it for the little extra effort. Check out wk2jeeps dot com for an explanation. Keep in mind too, that if you install a radio out of a 2012 you will need a security code. You'll probably also need a starscan tool or your dealer to activate your vin in the new radio. The antenna in the 2012 (and other years?) is both gps and Sirius, so you'll be fine there.
Thanks for the reply. I currently have the RER unit in my 2012 jeep. Everything works fine except the steering wheel controls for the uconnect and phone. The original radio was the 130 with uconnect. So, I know that the module for the 130 is redundant. I need to figure out the wiring to make the mic work or just get the mopar mic kit. Or sell the RER and get a RHR and I'm done. But, I'm not sure that I want to spend over $1000 for a radio. I could go aftermarket and get the Pioneer AVIC 130bt ( I have this in my ford escape). But, I don't want to lose all of my steering wheel controls. I have to tell you its a far cry from my 53 jeep.
Does anybody want to trade a RER for an RHR?
