Planning my total sound system upgrade..
Hey guys and gals, this is going to be a different sort of stereo upgrade. Years ago I installed high end car stereo systems. I mainly did box building, fiberglass/lexan/ aluminum enclosures, and full wound wiring harness building. While I have not kept up with high end stereo equipment in at least 10 years, I have recently gotten the bug to re do my '07 Sahara's system. I'm planning a double din head unit and amp/ speaker replacement and subs under the rear seat since I don't fold it down ever. I was planning simple, but while talking with my wife about it last night, she said "well lets get that box of stereo equipment out of the attic." Box of stuff in the attic? WTF?
So up I go, and there it is. At least 15 years old, brand new in the box AudioControl stuff I had planned to put in my old Carerra. A Model 11 Center Channel processor/ amplifier, 2 EQL's half octave/ full octave eq's with level matching preamps, 2 each 2SX 18 db per octave active crossovers, and an Epicenter bass restoration processor. Also a crap load of Esoteric Audio gold plated fuse holders, distribution blocks, terminals, Monster patch cables and some rolls of 0 gauge and 4 gauge power and ground wire. I had totally forgotten about this stuff! Just bench tested everything, and all is GTG. So now I am looking at this audio upgrade from a completely different perspective. I'm gonna see how much of this stuff I can shoe horn in to this thing. Why? 'cause I can and its here! Is an old school audiophile quality system overkill in a Jeep with no hard top (and 90% of the time, no soft top either)? Sure, but why not? Its free and its here! So before I re invent the wheel here, has anybody built under the seat (front and or rear)speaker boxed and component racks? My goal is going to be sub boxes that can be easily removed if I am going anywhere wet, and component storage that provides ventilation, but can quickly have a cover installed to water proof it. Any ideas or experiences appreciated.. Now, to tear that dash apart and see where I can install a center channel speaker.... |
I cant help much with what you are wanting but I will say that most of that old stuff especially around that time frame beats the crap out of today's junk.
Originally Posted by DKJEEP
(Post 3609595)
I have been thinkin about how to incorporate a center channel. Everything I've ever heard with a center channel just seems to have soo much more volume and clarity. It's like the last puzzle piece. It fits in perfect and is nice for those 3-4" speakers. Give you a little mid/high range vocals. Let me know what you come up with. I've been wanting to mold one into the cubby on top of the radio with two neo 3-4" speakers.
Originally Posted by bombout800
(Post 3610439)
I think some fiberglass work to create a slightly protruding, upward angled, speaker enclosure in the lower panel area in front of the shifter and I can shoehorn in a shallow 4 inch coax or 1/2 of a component set, or a 4x6 plate. I will probably need to do a little surgery on the change holder to get a good angle.
If not, I can really get involved and play with a WaveGuide BC-62 component set a buddy of mine never got around to installing. I've played with these compression loaded horn tweeters before. They are a bitch to integrate, but do provide an incredible front stage. |
Originally Posted by Davesrb
(Post 3610485)
If not, I can really get involved and play with a WaveGuide BC-62 component set a buddy of mine never got around to installing. I've played with these compression loaded horn tweeters before. They are a bitch to integrate, but do provide an incredible front stage. When placed in their own area not in the same axis or Near location they provide this different sound. Take a listen to a car which has a center speaker(s). its a huge boost in volume. Take a speaker and aim it at your face Then direct it off glass or some super smooth surface. Play with the angle and have a listen. Sometimes the surface in which its directed will, I won't say amplify, but boost certain frequencies. Your ears will pick up the change in sound. Check out some sound quality vehicles, the placement of the speAkers are key. What you want to do is not only have a great enclosure for the back side of the speaker but also the front. Sounds stupid right??? Place a speaker at your face in no enclosure. Sounds okay. But drowned out. Put it In the right enclosure and a 5 dollar speaker can turn into a thing of beauty. When In your jeep your speakers aren't placed facing up. They are faced in a direction to which the sound has some sort of deflection. When you can find tune whether you like on axis(pointed at your) or off axis, the possibilities Are endless. I'd say play with it. Make sure your have the right crossovers(passive) or amp that can run active to fully utilize the speaker in that location. Also get a few people to take a listen. Your thoughts while testing may be fine and you are happy. Put someone else in their and they make think it sounds terrible. Creating a new sound stage can be difficult to incorporate. But the best part is once you have the equipment it's game on. Don't give up it may take your a few times to get the sound you like. Post back your thoughts and build. |
Originally Posted by Mattk11
(Post 3610442)
Do it! I want to watch! |
Flat panel center channel speaker install.
https://i153.photobucket.com/albums/...ed-TopView.jpg https://i153.photobucket.com/albums/...View-Mount.jpg https://i153.photobucket.com/albums/...side-Mount.jpg Center Channel Speaker Spectral Response measurement in JK: https://i153.photobucket.com/albums/...l-Response.jpg |
(Post 3611017)
Personally I don't think that's a good spot for a center channel. But it never hurts to try. Your center channel is to be that. When down low its going to act like your front speakers.
When placed in their own area not in the same axis or Near location they provide this different sound. Take a listen to a car which has a center speaker(s). its a huge boost in volume. Take a speaker and aim it at your face Then direct it off glass or some super smooth surface. Play with the angle and have a listen. Sometimes the surface in which its directed will, I won't say amplify, but boost certain frequencies. Your ears will pick up the change in sound. Check out some sound quality vehicles, the placement of the speAkers are key. What you want to do is not only have a great enclosure for the back side of the speaker but also the front. Sounds stupid right??? Place a speaker at your face in no enclosure. Sounds okay. But drowned out. Put it In the right enclosure and a 5 dollar speaker can turn into a thing of beauty. When In your jeep your speakers aren't placed facing up. They are faced in a direction to which the sound has some sort of deflection. When you can find tune whether you like on axis(pointed at your) or off axis, the possibilities Are endless. I'd say play with it. Make sure your have the right crossovers(passive) or amp that can run active to fully utilize the speaker in that location. Also get a few people to take a listen. Your thoughts while testing may be fine and you are happy. Put someone else in their and they make think it sounds terrible. Creating a new sound stage can be difficult to incorporate. But the best part is once you have the equipment it's game on. Don't give up it may take your a few times to get the sound you like. Post back your thoughts and build. As for the electronics, I have the crossovers and an AudioControl System 90 Model 11 center channel processor which has an amp, 3 band eq and spatial sound processing with dash mounted controls that actually does a pretty amazing job. |
| All times are GMT -8. The time now is 11:02 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
