Please need help with rear Turn-light indicator
Hi. I have a 2014 JKUL sport s with stock rear turn lights. The left rear turn indicator does not work and I’m getting the error message under the speedometer.
Usually these were bulbs but I replaced and no luck. Then replaced the rear turn light wiring harness/pigtail and still no luck. The brake, reverse and rear tail light all work though.
Could this be possibly something in the turn stalk on the steering column? Any info helps and thanks for any guidance.
