JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   JK Electrical, Lighting & Sound Systems (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/)
-   -   Plug in replacement for 2012 dome light? (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/plug-replacement-2012-dome-light-232052/)
shakeman0 May 15, 2012 03:59 AM
Hello,
I'm looking for a simple plug in replacement blue led bulb for my 2-door 2012's dome light. Anyone have any idea what size it is? Are there two bulbs in there or just one?
Thanks,
shakeman0 May 15, 2012 04:13 AM
I found a pack of two 44m 6 led bulbs. Will those work?
EDIT: I don't think those will work. I just looked in the dome light and there are two small bulbs. They appear to be totally unmarked...
I was also looking at the Oznium bulb sets, but I really don't think there is anyway those would fit in my dome light. I don't have any open space available.
shakeman0 May 15, 2012 06:30 AM
I ordered a pair of 921 size bulbs. They should be here tomorrow. I'll post whether or not they fit for anyone that might be interested.
Shecky May 15, 2012 06:40 AM
They are 194 bulbs, I replaced mine with 5 diode LEDs and they are amazing. Also replaced my friends 2 door interior lights with the same bulbs.
shakeman0 May 15, 2012 06:53 AM
Thanks for the reply! I just switched my order to the 194 bulbs. You just pull the old bulbs out and stick the new ones in, right?
Shecky May 15, 2012 06:59 AM
The 921 might fit in the plug but it might be too long. I would just stick with the 194. Are you getting LED bulbs? If they only have 1 diode they won't be very bright cause it only points forward. If you get the 5 diode bulbs it will reflect in the housing as well as point forward.
shakeman0 May 15, 2012 07:03 AM
It says that it has 360 degree light. Looks like there are 9 diodes in total. Thanks again for the help.
Shecky May 15, 2012 07:09 AM
360 degree light will be perfect for the housing. The bulbs might be polarity sensitive so if you put them in and it doesn't work, pull it out and try it the other way.
Shecky May 15, 2012 07:23 AM
1 Attachment(s)
Attachment 317197
Here's a shot of mine
shakeman0 May 15, 2012 07:45 AM
Originally Posted by Shecky (Post 3015525)
Attachment 317197
That looks great! I can't wait for mine to get here now...
© 2026 MH Sub I, LLC dba Internet Brands
