Polk Audio speaker, crossover question
Old Feb 13, 2009 | 01:26 PM
ntense's Avatar
Default Polk Audio speaker, crossover question
Why would I have to use the crossover when I can use the existing wires? I'm not using a amp. Thanks.
Old Feb 13, 2009 | 02:16 PM
ntense's Avatar
Yea I'm not sure what to wire into to use the crossover.
Old Feb 13, 2009 | 04:01 PM
Vernnz's Avatar
Use the provided aftermarket crossover. It was built specifically for the speaker (tweeter) it came with. The crossover for the factory system is contained on the back of the factory tweeter.
How to wire: The crossover has an Input or Source or Stereo connection. That goes to the Head Unit or Amp. There should be two speaker outputs. One for the Woofer. One for the tweeter. Once you mount the crossover up under the footwell or someplace, get a few short pieces of speaker wire and connect from the crossover to the Tweeter and Woofer.
Old Feb 13, 2009 | 07:11 PM
ntense's Avatar
Can I use the woofer speaker wire for my input and then run my woofer and tweeter wire form crossover?
Old Feb 13, 2009 | 07:20 PM
Vernnz's Avatar
Exactly!!!!!!
Old Feb 13, 2009 | 07:21 PM
ntense's Avatar
Thanks Alot !!!!!
