power question
power question
Hi all just ran the wire for a AUKEY camera now just need where to hook up in fuse box, does anyone know which fuse is power on when started the book for the car is not really good ( says ignition off draw ) I have a jk 2017, thanks in advance oh and also do you just push the wire in with the fuse or do you put a clip on the wire, thanks again
Bill
Bill
Check your owners manual to confirm, but I believe M36 is what I have tapped for various things to run with ignition on. It is the fuse for the power outlet in the dash. That outlet on my '13 is only hot with the key on.
