Pull a fuse to disable the JK from starting?
So I need to park my jeep in an airport parking garage for five days. Of course I'll lock it, but I'd rather have a bit more security and pull a fuse(s) to disable the jeep from starting. I'm thinking J17 - Starter solenoid. Anyone tried to do this?
Thanks!
Thanks!
Maybe I am naive, but doesn't the fact that a chip in the key is needed to start provide enough security? I've parked my JKU many times at Newark airport and never gave it a thought about someone stealing it. Breaking in to steal stuff maybe, but not actually to steal the jeep.
An non-programmed key will start the jeep for 2 seconds before shutting it down. I've tried
You can pull any fuse you'd like but the fuel pump fuse would probably be just as effective if you're looking for alternatives to pull.
Not saying it'll help much, but maybe a bit more difficult.
I think it's fuse M11 (13 JK) but the fuse for the ignition will stop it from starting. I know this because my amp wire is hooked up to my ignition wire and I've blown the fuse twice, Jeep gets power but will not turn over.
